2004 Honda Pilot
This is my project on completely upgrading the sound of my 2004 pilot.
For the front I put in Alpine S-S65C Components
In the rear I have Alpine S-S65 Coaxial 2 ways
All being powered by Alpine BBX-F1200 4 Channel Amplifier
The hardest part of this project was running speakers wires and the power wires.
I thought it would be to hard to run the tweeter wire through the dash so I went with a flush mount on the sail panel which I think would sound better anyway
2008 Honda Pilot
Really kool
Isn't that amp a bit underpowered for the task? Those speakers are 80W RMS, 4 Ohms. The amp can deliver only 50W per channel into 4 Ohms (70W per channel at 2 Ohms). I would probably consider something like this in similar price range:
Sound Ordnance M75-4 Compact 4-channel car amplifier — 75 watts RMS x 4 at Crutchfield - 75W x 4 RMS at 4 Ohms output.
Also, are you doing anything about the sub and head unit? If you are not upgrading the head, how are you feeding the amp? I am not seeing speaker level inputs on the BBX-F1200
You will either need a 4-channel line level converter, or go for an amp with high inputs, i.e.
JBL Club A754 Club Series 4-channel car amplifier — 75 watts RMS x 4 at Crutchfield - also 75Wx4 @ 4 Ohms.
