Gauge lights not working. Checked manual and it identifies a fuse in the driver's side panel that should be for both gauge lights and back up lights. checked... fuse appears ok... and the backup lights work.
will go pick up a new mini fuse tomorrow... but don't see how one set of lights could work and the other not (if the manual is correct).
Just to be sure, you turned the little straight knob in the middle of your speedometer all the way to the right, right? That's the dimmer for your panel lights.
Have you tested the fuse with a multimeter? Sometimes you can't eyeball a failed fuse.
From other posts... discovered it's actually a poorly labeled fuse in the manual. Its the small light fuse 10 in the passenger fuse panel. Gonna pick up a pile of them and see whats up
Good find. Post your results.
