Does anyone have a link to a video on how to remove the front lower ball joints on an 04. Is there a clip I'm not seeing? Can't seem to figure out the ball joint press. Any help is much appreciated. HELP!!!
YouTube
Lower control arms replacement ..BUT it will show you how to remove the lower ball joint.. did you rent a ball joint press or did you buy one ?
send a link or a PIC so we can see what type your using.
Discussion Starter #3
I watched the video. I didn't see the guy remove the ball joint from the control arm. I will post a pic of what I have. It is the rental.
I use the same tool as Tahoefever, a Gearwrench lever press. Here's a tip: after you tighten it up and put pressure on the ball joint, then strike the casting around the ball joint taper smartly with a hammer. You can use a hammer and a steel drift to hit the casting as well. It will pop right out like a shot. Careful, it will really fly out of there!
