My 2004 Honda Pilot has been slowly developing more and more flicker on the Parking Brake Dash light on idle, acceleration, and braking. But more recently, there is a slight hiss, like an air leak, through my car when I accelerate over 2.5k on the tach. In this video I do a quick 30-100, and there is no radio, no AC, just silent ambience and you can hear some hissing as if a window was cracked open. Here is the video.
Is the parking brake cable or perhaps the parking brake itself sticking? Merits investigation.
OK,
2 things
I thought Pilot engines are VCM, NOT Vtec?
and 2- when people drive Sportbikes on the streets passing cars like that- I/we call them squids. IMHO- you drive like a squid.
Check your brake fluid level. If low, check to see which set of pads need replacement.
Premium Member
2005 Pilot EXL- 227,700 Miles
Also, check the brake fluid cap and connections while at idle after checking fluid level. I had to top mine off ( it wasn’t at low level mark or even close) and clean connections to get light to work properly.
