'03 and '04 were pretty close in terms of features and drivetrain - mostly little things.
'05 made a significant change to the drivetrain on the EX-L models - added VSA, retuned the tranny, and added a sunroof. I think drive-by-wire was added as well. The reason for the lowered gas mileage was because of the modified shift points with the upgraded tranny/motor tuning package. This carried over to the '06 redesign.
We had an '04 EX-L and an '06 LX (both 4WD), and the driving difference and MPG difference were noticible - easier to get higher MPG's on the '04 than the '06, but the response on the '06 was much "peppier" than the '04.
So, if you can find an '04 with decent features and low miles, you'd have a very solid car that would tend towards higher MPG's. But you'd lack VSA and sunroof on the EX-L models since the '05 added those...
andy
It's probably pretty obvious that I don't post much...and yeah, I'm necro'ing this thread. But I just wanted to add a bit of a postscript. I stumbled upon it again when I was looking for info on the '03 Pilots. So attached are all the major costs for maintenance and repairs on my '03 Pilot since we bought it. It's now just a few weeks short of ten years later.Alright, that helps.
The oil is being changed by the dealer. I'll look into changing the transmission fluid and this "3rd and 4th gear switch" of which you speak...just as a preventative measure.
Early June my dad and I will probably tear into it a bit just so I can familiarize myself with the vehicle. I might try to do the transmission fluid change myself - unless you would recommend against that.
I'll try to check the timing belt at the same time. Perhaps I'll plan on replacing it and the water pump sometime next year? Mainly because I don't have a real clear record of the work done on the vehicle.
I don't mind spending a little extra to do preventative work and play it safe. I figure it's cheaper than a major failure while on the road a thousand miles from home.
We average 6500-9000 miles a year on the main vehicle. I intend to get 7-10 good years out of this vehicle.
Again, thanks for your help. I do appreciate it.
Would love to hear how you dealt with the transmission issue you had. Looks like you didn't have to replace it after all. Looks like you had the trans fluid done at Midas. That is scary. Do you know if they used Honda fluid, or just any trans fluid. That could have been a root of your trans problems. They did your brake fluid as well. Did you develop any leaks?It's probably pretty obvious that I don't post much...and yeah, I'm necro'ing this thread. But I just wanted to add a bit of a postscript. I stumbled upon it again when I was looking for info on the '03 Pilots. So attached are all the major costs for maintenance and repairs on my '03 Pilot since we bought it. It's now just a few weeks short of ten years later.
We've gone from 88k to just under 170k. It still has the original engine and transmission. I've religiously done oil changes every 3k miles, or had a shop do it if I was too busy. And then once a year I change the transmission fluid too.
I think the only real noteworthy item is that the rear main seal has had an on again/off again leak for about three years. The local mechanic told me if I'm not seeing it hit the garage floor and then keep an eye on the oil level, and don't worry too much about it. Between oil changes I have to add about 1 qt. He also recommended that I also switched to Mobil1, 5-20 'High Mileage' and that actually seemed to refresh the seals enough that the leak only reoccurs in cold weather, if at all.
