I recently bought a 2003 pilot for 250$ for a winter beater. The guy who had it said it overheated and thought maybe it was a head gasket. And that it also need valves adjusted. I pulled plugs all looked good besides one wet with gas which I’m assuming because of valve adjustment which I just finished. Put it back together and changed thermostat. Got it up to 200 degrees and neither fans come on. If I u plug the sensor on the bottom of the radiator and jump with a piece of wire both fans come on. So I would assume that the sending unit on the radiator is bad but I’m not familiar with Honda and was hoping some knowledgeable people on here could confirm it. Thanks
Welcome to the forum.
That sensor must be unique to 2003/04 Pilots since I’m sure there isn’t one on the 2005 radiator.
I think your logic that the sensor has failed is sound since as you mentioned shorting across its leads causes the cooling fan to turn on.
I get most of the parts for my Pilot from:
Agree that the sensor sounds like the issue. I replaced the radiator in my '04 a few months ago, and the new Denso unit did not come with this sensor. Wish I would've known beforehand as I had to get it back in service and re-used the old one. All good since. If I were you I would just go ahead and replace the radiator & sensor. Less than $150 in parts, 3-4 hour job.
