I am in desperate need of bump stops and seat insulators. Any suggestions on where and what brand or kind I should buy?
2007 EX-L 219K
When I think of "bump stop" it is inside the lower portion of a rear spring as in the picture below (circled)
149435
Is this what you mean? I'm not familiar with the term "seat insulator" so you would need to be more specific.
Yes that's it. The seat insulators are what the coil spring sits on. #6 in the diagram is the bump stop. I would prefer to replace with something other than rubber say polyurethane or something like that
2007 EX-L 219K
2006 Honda Pilot EX-L - - 226k 2007 Honda Accord SE - - 145k
Not sure where you will find a poly, seat insulator. The OEM rubber part # is: Honda Part No.: 52748-S0X-A00
Good news is that both parts (OEM) are inexpensive but not available at my go-to supplier, RockAuto (may have missed something). I do have a 03-08 Coil Spring and Bump Stop replacement guide (photos / narrative instead of video) if that helps: Honda Pilot Rear Coil Spring & Bump Stop Replacement Guide
Hey, you're Paul? I've used some of your tutorials on my pilot and my sonata!
