2003 Honda Pilot Try using RCA jacks that go to DVD player I noticed one side would play if I switched on the other side same thing I can’t get both to play at the same time will play or used fouur different kinds or Rca jacks still same problem little bit of help
One of my RCA cables is miscolored (or is it the jack?), so try all different permutations, including the yellow video jack for audio. When you find the right combination, label it with a sharpie.
Also, what's on th other side of the cable? If it's a 3.5mm plug, make sure it's plugged in all the way.
