Hello Piloteers! I've been browsing this forum for a couple of months but have finally joined.
I bought a 2003 Honda Pilot in October (170k miles). It had known transmission issues and the guy sold it to me as "salvage". At the time, it barely drove forward and would not go in reverse. The codes I got immediately off the OBD2 reader were P0730 and P0780. I researched this forum and YouTube heavily and started performing various tweaks. I started with Something to check on higher mileage Pilot transmissions which showed the clutch solenoid (Control C) and the A/B solenoid getting dirty.
I started with the low-hanging fruit - the clutch solenoid. I pulled it off and found debris on the screen. I cleaned it off and put it back in. The gasket was very rough looking though and started leaking, so I ended up ordering a new solenoid altogether (I couldn't find a gasket on its own). With that replaced, I also performed a drain and fill with 4 quarts of DW1. The fluid was pretty bad looking and the drain plug had a bunch of gunk on it as well.
After that, the car appeared to be driving a bit better - I could get it in reverse and it was somewhat drivable forward. First to second is pretty smooth, but when it goes from second to third, there is a slight delay and then it jolts into gear. Third to fourth is smooth. The other issue I have found is that at high speeds, usually going uphill, the car will appear to shift down to first (or something - the revs go WAY up) before shifting into what I assume is 5th. This only appears uphill and accelerating.
The next thing I worked on was cleaning out the A/B. I noticed some debris on those screens, but it wasn't nearly as bad as C. Unfortunately, I snapped off one of the connectors trying to get it back in - so I had to replace that one as well. I did one more drain and fill of DW1 when I replaced it - the fluid still seemed pretty dirty (and more gunk on the drain plug).
Now the interesting part - I have noticed that if I drive it for a while, park it, return within 20 minutes and start it again, it shifts and slips horribly. Once I started letting the engine run for a couple of minutes after parking before shutting it off, this stopped. I figured heat had something to do with this after reading this post. It has gotten quite cold here and the car is shifting pretty much perfectly now. I have bought a new transmission filter, but have yet to install it. I want to know if I'm making the right decision to change it or not.
I have performed various additional maintenance like fresh oil and new spark plugs. But the issue remains - if the car gets warm enough, shifting between 2/3 is noticeable and the hard downshift going up hills at high speeds happens occasionally. Should I put the effort in to change the transmission filter, or would this be futile? Any other suggestions would be appreciated. I was prepared to buy a new transmission if needed, but I'd still like to try anything else to repair this one first.
