Year:2003
Make:Honda
Model:Pilot
Mileage:266000 M
Transmission:Automatic
Engine:N/A
Trim:EXL-RES
I recommend to only purchase this vehicle as a parts donor.
Clean Title, runs and drives great.
Vehicle Needs:
Noisy A/C Compressor
LF & RR Door lock actuators
EVAP Canister
Rotted Rear Subframe Cross Member
Vehicle Has:
New Tires
New Front Struts/Links
Timing Belt/ WP Replaced 50K Ago
New Battery and Starter
Radiator replaced 50K Ago
Spark Plugs New and Valves Adjusted
Fuel Induction Cleaning every 50K
Transmission Fluid Every 30K Since birth
Catalytic Convertor has 80K on it
Cat-Back exhaust to Muffler is a few months old
Interior is all operational including the Rear Entertainment System.
I am an ex Honda Master Technician that planned to drive this vehicle until 300K, but can no longer continue due to the excessive rust on the rear cross member, that’s why I recommend to use only as a parts donor. The rest is up to you.
The exhaust and tires alone are worth the vehicles value.
Vehicle is located in Massachusetts
Vehicle Needs:
EVAP Canister
Vehicle Has:
New Tires
