1 - 8 of 8 Posts
can i use 18 inch 245-60R-18 on touring 20 inch model? does it make difference ? just need to know
Super Moderator
No, the last number in the sequence of 245.60R-18 signifies the size of the rim?wheel the tire will fit on. For those tires you need to buy 18" wheels or buy 20" snow tires for the stock rim size.
The first number, 245 is the tire width, the second number 60 is the aspect ration, R indicates it is a Radial Tire, and the last number 18 is the rim diameter. This explains how to read the markings on tires.
139725
If you are asking can you downsize from the Touring standard 20 inch wheels and tires to an 18 inch tire and wheel as your topic header states , then yes you should be able to. The 245X60X18 is an optional factory installed size put on the LX, EX-L, and EX 2019 models. Should be the same for the 2020? I believe many owner's put the smaller sized wheels and tires on for winter tires.
Should be no problem what so ever. Here is a comparison of the two sizes.
139728
Reactions: EFICTION
Certainly a much more cost effective option going to the 18" steel rims and snows. I just have to get some sensors installed in mine so I don't get the TPMS warning every time I start the car.
Be careful....once you jump down to 18 and realize the comfort you may not ever throw those 20's back on. Just sayin...
I'll be watching the Classified ads for a while then!!!! Could always use a spare set of 20's for my Touring!
Reactions: EFICTION
I ran 17" wheels with winter tires for three winters on my 18 Pilot EX-L. Not much difference in ride or handling, just a little better in the snow than the OEM tires.
What size 17’s did you put on? I have a set from our 2013 Caravan that I’d love to just get the proper rims for and throw on my 2019 Touring
1 - 8 of 8 Posts
