2017 Pilot EX-L AWD
whenver i turn on the climate control, it whistles. doesnt last for long. seems like the faster the fan speed is, the louder the whistle is. and suggestions as where to start? i recently changed the cabin filter. noise was there before and after the filter change.
It could be the bearing in the fan. I’ve had to replace mine at 40k miles. The whine was most noticeable at low fan speed setting. There are two cabin fans, one for the front and one for the rear, you can play with the fan settings to find the one making the noise. Replacing the front fan was a very easy job, the part was about $70.
2017 Pilot EX-L AWD
thanks! ill look into it!
