1 - 16 of 16 Posts
I have a 15 Pilot that has a hard hot start. If I drive to the store go shopping and come out in 20-30min it will crank for 10+ seconds before it starts. Any ideas anyone?
Do you have a check engine light?
Just doing some research. Sounds like your fuel pump relay is going bad.
Reactions: Daltongang
If the fuel relay does not fix the problem, you might want change the fuel filter. Not an easy process as it is in the fuel tank itself. I do believe on the 2015 you can get to the pump from the cargo area, instead of having to drop the fuel tank.
You may also want to get a pressure check done on the fuel pump itself, as well as the fuel pressure regulator.
There was a question tossed out there, was this going on BEFORE you changed your timing belt ? It sounds like your timing is off ..this will cause the issue your experiencing if it is.
I’ve replaced fuel pump & main ignition relay to no avail that was my first thought.
This was the hope for an easy fix.
What is your current milage?
Discussion Starter · #12 ·
950000
Thank you, it started after the belt was changed not immediately but after. I didn’t do the job myself but I did consider that to be the problem so I took it back for them to recheck it and they said everything lined up. Maybe I’ll just have to take a look myself.
950000
I had the same situation myself if your able to look at the job yourself that would be great I was told by a shop it was lined up tore into it myself only to discover the rear was off by a almost a full tooth.
Discussion Starter · #15 ·
Okay thanks you've helped me make up my mind I'm going to check it myself, very capable, I should have done the job instead of being lazy.
1 - 16 of 16 Posts
