My '12 had been making a whining noise that changed pitch with RPM, which came and went since Nov last year. I stethascoped it back then to make sure it was culprit (it was) and also measured the charging voltage, ripple voltage and charging current, which were all nominal. Just last week @ aprox 131,000 mi, the whining suddenly increased in volume, and the charging voltage was erratic between 12.2 and 12.8v at idle. With the A/C on, the truck stalled once at a traffic light; assume the charging voltage was really erratic and the PCM became unhappy. I replaced the alternator with a Denso refurb from Rockauto. $145 + core charge. Charging normally and quiet, now.
On a similar note, three weeks ago I got a P0685 code and check engine light. According to Google searches for cause, the main PCM relay often sticks "on". It doesn't cause any drivability issues, although I suppose if the truck were left sitting for a week, it might drain the battery flat. I pulled both primary and secondary PCM relays, nipped the corner of cases off to expose about 1/16" hole, and spritzed the innards with Deoxit, shook out the excess, sealed the hole with hot glue. Cleared codes. Thus far fault-free. The genuine Denso replacement relays are STUPID $$$.
Nicely done on both accounts!
Now this is useful info. Thanks for posting. ?
AVC - I also have the P0685 code on my pilot and would like to ask if you would please confirm the image below or otherwise include a picture (or some identification info) so that I can locate the correct relays in my pilot? (& Thanks!)
135791
While I admire the McGiver solutions that get us home safely or help with diagnosis, replacement of those relays is really a better longer-term option than washing off the slag on the contacts. In my limited experience anyway.
Reactions: bdozer1965
In this case, I preferred the "Russian" fix. Understanding the failure mode (won't leave me "stranded" unless I park the car for a week), and that for 40 years I have used Caig to successfully remedy sticking contact relays, I'm OK with it, rather than $100 in relays. Maybe the same for other DIY's. Maybe not. They have gray matter. Maybe the fix lasts a few months, or a few years, or for the life of truck. Whatev....
As for the relay locations, I'll try to pop the hood this evening and look (it's my wife's daily driver)
What's so special about those two besides the red cases? Do they have suppressor diodes built in? Trying to decide what makes them $110 for the pair...
They're ultra-high MTBF.....LOL.....
