1 - 20 of 21 Posts
So I have "inherited" my wife's Pilot, aka she wanted something new. It is time to refresh the suspension with new struts and shocks. Here's my purchase list, please let me know if I am overlooking anything. Thanks!
Front end:
1. Bilstein B6 struts
2. Strut bellow kits
3. Strut mounts
4. Sway bar links
5. Sway bar bushings
Rear end:
1. Bilstein B6 shock
2. Sway bar links
3. Sway bar bushings
What am I overlooking? Should the OE springs be replaced?
So you are getting just the struts for the front, not the preloaded struts with new springs?
On one hand springs are easy to replace while you are in there, on the other I can't say I see a lot of Pilots with weird sags indicating the springs are bad.
Bilsteins only offered as separate strut, no loaded kits.
Unless you feel like your Pilot is sagging, I wouldn't worry about replacing the springs.
Reactions: 97trophy
I would not mess with springs personally, they can be known to sag over time, but ours have 111k and still have excellent rear camber. I think you got it.
Why sway bar bushings and new links? Just assuming they are shot and trying to stiffen up the ride and handling?
How do your compliance bushings look on your control arms? They can give a lot under cornering when they are shot.
Compliance bushings were updated after Honda admitted they were a problem. I just feel it would be best to replace all that rubber while I am in there on the end links and bushings.
wasn‘t there a recall or TSB on those?
There was an extended warranty program which extended the coverage on these bushings. If they were determined to be defective, they would be replaced up to 8 years and 100,000 miles.
Discussion Starter · #11 ·
Refresh? Is anything sagging, loose, banging or knocking? Unless you've got some symptoms, I'd leave these alone.
Yeah, thinking refresh. Can't tell if anything is sagging as this is my "new" vehicle. I didn't drive it much before it was handed over to me.
Discussion Starter · #12 ·
After input on this thread and reading a few others, I am going to try just an install of the Bilstein B6 all around. Luckily there isn't any noise coming from any of the corners, so I'll see what happens. I'll also be installing a set of Cooper Discoverer A/T3 4S in the OE size as the deal I got from tirebuyer.com was great and we'll start using this as a light off paved road explorer for some camping and fishing.
At 118,000 miles, sway bar bushings and links are probably worn. That said, then they should be making some clunking noise on bumps if they're shot.
I did all of this over the summer. The most difficult part was removing the sway bar links and getting the bottom bolt out of the rear shocks. I eventually had to cut them out. You may want to consider ordering the bottom bolts for the rear shocks, due to this. Also, I went with the Honda struts. I initially installed aftermarket and they were noisy (tried 2 different sets before this). Good luck!
Didya do it yet?
Discussion Starter · #17 ·
So it took a few months but Covid-19 turned our life upside down. Anyways, new Bilsteins at each corner and the Cooper Discoverer A/T3 were installed yesterday. Pilot has right at 120,000 miles on it and it rides better than new. It is insane how much of a difference the new struts/shocks made. Socially distant adventures await!
Thanks for the update! Did you end up installing the sway bar bushings? Did you have to lower/drop the subframes to get to the mounting bolts? I plan on doing it next week so any advice would help. Our Pilot is at 148k and is a sloppy, clanking, squeeky mess. LOL.
Discussion Starter · #19 ·
I did not end up messing with the sway bar bushings or links. I didn't have any squeaks or slop from that end of things.
I'm in the process of doing th
So it took a few months but Covid-19 turned our life upside down. Anyways, new Bilsteins at each corner....
My covid'cation is a new engine in our 09, so am putting in B6's while waiting on engine parts and machining. Did you replace the strut boot? And if so, what brand did you use? Reviews on Amazon hint that KYBs are too tight and Monroes too short... So before ordering, figured I'd ask.
-Matt
1 - 20 of 21 Posts
