1 - 2 of 2 Posts
Hi Folks,
My 09 Pilot has dual zone HVAC, the passenger side gets cold, the second and 3rd row get cold but the driver side only cools slightly when moving. Also the air only blows on the dash and feet, if i press defog or any other vent, it doesn't change. If you have had this issue before let me know where the culprit is so I can replace it.
Thanks,
JR
I would check the operation of the mode motor which control which way the air flows. It is the upper motor on the passenger side and you can view it's operation if you remove the upper dash piece. Search on here for mode motor repair.
In regards to warmer air on the driver side, check the mix motor on the driver side on the side of the center console near the gas pedal. There are threads on here and videos of how to check their operation.
1 - 2 of 2 Posts
