21 - 21 of 21 Posts
Hi Newbie here with a 2016 EX-L. The spec sheets say that it would only fit the 2019 to 2020 pilot. To my knowledge there are no body changes, will it fit on my 2016?
I'm putting mine on my 2019 later today. Scorrpio and others have said no it will not fit, others have asked bit I don't think anyone has really tried. In my opinion they would fit, here's why. The part #'s for the side rails for silver or black are the exact same for 16-18 and 19-20 and instructions for both versions are the same.The cross bars are the exact same part# for both 16-18 and 19-20. If you buy the lower priced rack only version listed here you could pull the flat rail and check the rack mounting with no cutting. If it lines up for bolts you are good then just cut accordingly per instructions. If not relist the base carrier here for somebody else.
21 - 21 of 21 Posts
