1 - 2 of 2 Posts
Hi folks. I contacted a manufacturer regarding a power steering pump. I asked them about the difference between Ody and Pilot pumps. They said that the one of Odyss has more presure than the one for the Pilot. My steering is a bit heavy even after buying a pump from 1A auto. Before I change my Rack and Pinion I would like to try an Odyssey pump. I see some online that say it does fit. But that manufacturer said that it doesn't.
So my question is: has anyone put a Odyssey steering pump on a Pilot. And if yes, did it make a difference ?
If it bolts on, it should work. If you can pair it with the Ody high pressure line, that would do it. If however the line is the same part between Ody and Pilot, then that would guarantee the Ody pump is just a bolt-on.
1 - 2 of 2 Posts
