Hey guys new to piloteers. My wife's 08 Pilot has gone into limp mode. I scanned it and it ran a p1659 (tacm relay stuck off) I checked the relay under the right kick panel and it worked fine. I also checked the fuse under the hood also fine. So I was curious what you guys thought it might be?
Switch out the relay with an identical known good one to double check.
Welcome to the forums. :)
Miss our 2005 Pilot
Welcome to the forum.
What method did you use to check the fuse and the relay?
That's another thing I did try, still not positive which one is for the throttle control. It's a group of 4 relays one of which is for the rear washer.
I took out the relays and put 12v to the load side and then checked for continuity across the component side. As for the fuse just checked for continuity across the 2 posts.
Miss our 2005 Pilot
Sounds like you used a multimeter, so that rules that out.
On my 2005 Pilot I can tell you one of those relays in the cluster is for the fuel pump.
