I have a 08 honda pilot and recently the front heat/ac only blows warm air. I checked the control valve and cable on the firewall and fod that the cable is connected but not moving when changing the temp controls from cold to hot and back to cold again. Could the cable have come loose on the inside or could it be another problem?
Gotta love how even though all the knowledgeable folks on the forum know the fix, they've respectfully deferred to me to provide the answer, since I'm the go-to "screw loose" guy around here, it seems. :)
So yeah, tighten that screw.
I should've explained that I had already checked that screw. It was tight. Checked under dash. Cable does not move.
Have any WD-40 on hand?
Can you disconnect the cable at the control valve, and then will the valve move to open and closed?
To inspect the actuator:
Reactions: plplplpl
In all my experience with this problem, the blend door actuator had to be replaced. Did it start out clicking over and over before it stopped?
134130
Although first you might want to try just nudging it back into action. Sometimes that's all it takes.
