What year engines can I swap into my 08 pilot? My current engine has a crack in the block. I tried using a 05 pilot engine but found out that the mounting for the starters are different. So.... what years can swap into an 08 pilot? Like can I use oddesy, mdx, accord? Am I stuck with only 08 pilots
Do a parts search on Car-part.com. They will only bring up compatible engines.
Are we talking just an engine block without heads or transmission?
If it's a total swap it's necessary to find an exact match. Major factors even if same year model are
2 or 4 wheel drive and Transmission type.
Research your engine code and transmission code. Don't buy unless there an exact match with what you have.
I'll have to try that
And it's just the engine. Dont really have the money for everything.
