1 - 14 of 14 Posts
My VTM-4 ,VSA, ABS lights r all on how do i test to figure out the problem...Thanks
When you get the codes read ask if their reader supports Honda specific codes. VTM-4 codes will not likely be deciphered by a generic code reader.
And welcome to the forum.
Also verify that the battery and alternator are working properly. I had some of those lights come on and it turned out to be a weak battery. I didn't have any problems starting the car or anything, but it was enough to cause the computer to hiccup.
Up date battery was good n alternater was charging.... Put on scanner it was left frt speed sensor or ABS sensor.... Replaced that sensor ABS light went out n also VTM-4 went out but the VSA light n triangle stays on...when you start the car just to triangle is on then when you start driving the VSA lights up... Any ideas...
There are a few things you can try. Read this thread to find out how this was eventually "resolved":
Reset VSA Light and Indicator
Which way do u count the pins for the 4th pin n the 9th pin.... U hv a pic of it plus the procedure I see different people talk about it but there's no pics to see where the pins are top or bottom when you're looking at it...Thanks
Here you go.
138707
138708
Discussion Starter · #12 ·
Used the jumper wire and follow the procedure with clearing the codes first time didn't work second time all lights went out ....thanks to all
1 - 14 of 14 Posts
