My front windshield washer won't work I pulled the pump and applied 12V and works fine. I put a volt meter on the plug that feeds the pump and discovered it is only receiving 3v when the switch is activated. I though it could be a problem with the switch on the steering column or perhaps the Multiplex control unit. Any thought? I haven't been able to figure out where the Multiplex unit is
Or mice or other rodents chewing on your wires. They apparently get a buzz from that. Test wire continuity with a multimeter.
The MICU is in the under dash fuse box.
145810
