My 2007 Pilot AWD is blowing hot air even after adding Freon. After a couple days it was back to blowing hot air. Now, after further investigation, I noticed the compressor was not engaging. Any ideas?
Start by looking at the relays controlling the compressor
Text Diagram Line art Auto part Design
Did the system work for a while after adding Freon ? If so, sounds like a leak. Compressor will not cycle if too much refrigerant leaks out. You probably need to have a pro find and repair the leak.
+1 for checking the relay that controls the compressor clutch. I had the same part go out on my '10 Civic and a new relay was $5 at O'Reilly.
