1 - 10 of 10 Posts
"06 Pilot EX-L AWD Nav
I'm 500 miles from home. I don't have any testing materials with me and all 4 of the Power Windows stopped working and the Passenger Window is down! All I need is to see/know the color of the 2 wires that run to the Passenger Power Window Motor - so I can power the Motor to closed the open Window until I get back home. Thanks in advance!
Per my Haynes manual front passenger window motor is connected at the motor via blue/red and blue/white.
You might check fuse 9 in the driver side under dash fuse box as well. That fuse supplies power to both the driver and passenger control units. Also check fuse 13 on the passenger side under dash.
And just to avoid a facepalm, check to make sure your rocker switch is on.
138425
I think with that master off switch engaged the driver window still operates.
Reactions: Sha93
Eek, you're right. So now I'll be the only one to blame if there's a car wash mishap. 😰
So yeah, fuses.
In case you still need it, here's the Power Windows section from the 2006 Honda Pilot Service Manual;
Thanks for the help! All Fuses are good. I went to a hardware store and bought a 12 foot Extension Cord. Cut off the ends. Hooked one end to the battery. Removed the Drivers Master switch and the Passenger P/W Switch. Back probed the connector for the Passenger Switch on the Blue/Red and Blue/White wire to close the Passenger Window (Motor is good). Now that that Window is closed - the vehicle is secure. When I return home, I will troubleshoot the system. I think the problem is the Drivers Master Switch.
This is the first issue that I have I have ever had with my Pilot. I bought it new in February 2006!
1 - 10 of 10 Posts
