05
206,000 miles
Since I purchased this pilot 3 years ago, it has had a shudder at idle. Its not mounts or anything like that, it feels like its the engine/fuel/battery. It was a lot worse when I got it, thats when I went tracking the issue down. Cleaned the top end + intake manifold + throttle body, did timing chain, mount, water pump, OEM recommended plugs and coil packs. I don't remember what the plugs were, but the coil packs are denso. Replaced the battery and cables as well. I'm not sure what helped the shuddering, but something did, because its a lot better. Since then, its been a mild shudder, but its still there. Now it seems to be getting a little worse.
What do you think it could be? Anyone had similar issues? Common vacuum leak? Alternator? Dirty injectors?
Your engine is at 206K miles. Have you reset the valve clearances ? If not, it's due ASAP --could be the cause for a rough idle.
Discussion Starter #3
I did have the valves "adjusted" by a shop. I had this done because at about 180,000 miles the timing belt tensioner failed and the belt nearly slipped. Had them adjusted just in case. Is this something I can check/rectify myself being a weekend mechanic? I don't have a TON of experience, but I am fairly mechanically inclined.
No codes?
Mine coded EGR around those miles. Idled terribly highway fine. Held in by two very tight bolts. I was lucky to break them free without too much of a struggle.
Discussion Starter #5
No codes?
No codes. I almost wish there was so I would know where to look.
I wonder if its some sort of vacuum leak?
Vacuum leaks usually result in high idle, not rough. Rough means lack of fuel, lack of ignition or lack of air.
