05 pilot cranks but wont start. fixed a couple ground wires and reconnected the drive belt. found fuel pump turns on for a second and then it stops pumping. is the fuel pump bad or is this a immobilizer issue? any help is greatly appreciated
What is the green key icon on the dash doing while you crank the engine? If I recall correctly the normal behavior is for it to blink for a few seconds then turn off when things are performing normally.
And welcome to the forum.
Have you switched keys or otherwise modified them? What happens if you use your second key?
If you're sure all your cables are OK, including grounds, then maybe carefully look at your main relay PC board for a bad solder. It's not as difficult as you might think, as long as you know about it.
