'04 Pilot, OPDS Unit Fault Code 15-1 not clearing
5847 Views 5 Replies 4 Participants Last post by  car5car
Help request.
OPDS Unit Fault Code 15-1.
I've replaced with 2 separate used units. Can go through initialization sequence OK on original OPDS unit & both replacements - but the SRS warning light reappears a few seconds after the last 2 blinks of the light.
Fuse 7 shared with rear wiper motor is OK.
Any suggestions on how to proceed?
The only way i found to correct the issue was to purchased a scan tool ( foxwell nt630 pro) that can clear / resync the SRS light.
Tahoefever,
I got a Foxwell 630Plus unit that can reset SRS codes. It is not even scanning the SRS system. Got a "No Communicating" message.
Any suggestions?
I used www.safetyrestore.com to reset my SRS module.
Tahoefever,
Any suggestions?
I had the same issue in my case it needed the new firmware / software update ..did you happen to update yours ? its free from the vendors website .
Also make sure it's fully seated in the OBD port mine will give me issues staying in the port time to time.
Tahoefever,
Any suggestions?
Try another scanner. If it doesn't work, there are 3 possible reasons:
wire between OBD connector and Air Bag module is broken (not likely)
module is bad (most likely)
voltage and ground are disconnected from module
