1 - 19 of 19 Posts
I'm new to the site! I've had an 04 pilot for 4 yrs and while I love it and it's been the most reliable vehicle I've ever owned it gets bad mpg. I've read through a lot of threads about mpg and people talking about doing this or that I see no one has mentioned that the rear 3 cylinders come down and loop like a J into the main pipe! This is a terrible design and a major restriction! It seems every aftermarket pipe is like this also. I think if it came down into a Y pipe it would help with this mpg issue.
Have you tried cleaning or replacing your EGR valve and cleaning out your EGR passages? That can help with MPG.
Super Moderator
Welcome and thanks for registering at piloteers.org. We are glad you have chosen to be part of the community and we hope you enjoy your stay.
Please take a moment to look over the FAQ section. If you need assistance please use the “message” function to contact any staff member.
If you haven’t already, don’t forget to register at the Honda Owners web site. It is full of information you may find useful about your particular Honda vehicle(s).
Enjoy and all the best,
Daltongang
Welcome @royb ...what kind of bad mpg are you getting? The Pilot is a 4400 lb cruiser and mpg is never going to be economical 25+
Yeah I know it's never gonna be getting 25+. I'm getting anywhere about 19 on the highway. It has 125k miles and I keep all fluids changed, tires aired up, plugs changed and air filter. I even changed the 02 sensor. When I got it it had 74k miles. I've also wondered if maybe the coil units are putting out weak spark but they cost so much I havent wanted to change them all.
I havent tried the egr yet but I will. I'm about to prepare it for winter so I'll do that then.
I'm not getting any misfires but I'm gonna pop this plate off and look and see if maybe these ports are getting plugged and then check the egr.
I think your maintenance plans are going in the right direction. MPG seems good for the first generation Pilots. Any changes in your avg mpg can be a good clue that something is not normal.
Besides a clean Air Filter, thoroughly inspect your plastic air intake tube. These are known to become brittle and crack with age. They can crack on the bottom where we can't see it. Inspect around the clamps and make sure clamps are tight.
Reactions: plplplpl
2008 Honda Pilot EX-L
What's your cruising speed on the highway? Biggest improvement one can make to MPG is to change the nut behind the steering wheel! 😋
65 on the freeway usually. I try and keep it under 2k rpm's
Run the A/C at all? How about the rear defrost? (Both cause the A/C compressor to kick on)
What time(s) of day do you fill up your gas tank? (Best time is right before sunrise, as the gas will be it's densest in the underground holding tank).
Do you use Top Tier gas? What grade/octane you normally put in it?
When was the last time you ran a fuel system/injector cleaner through it?
Also, what was the ambient temperature outside (on average)?
Do you drive with the windows open at all?
As an FYI, the EPA whom defines the "highway" fuel economy as averaging 48.3 mph:
140000
Optimal cruising speed for absolutely best MPG is around 45mph for most vehicles.
Have you checked your vacuum reading? Check for leaks. Vac hoses get old and dry.
Have you replaced your valve cover gaskets, spark plug tube seals and bolt grommets along with a new intake manifold gasket? Again, just trying to seal things up because of age.
New PCV.
Discussion Starter · #14 ·
No leaks. All hoses and everything are in good condition. I run injector cleaner pretty regular and use regular unleaded and dont run the air much
19 is right on the money at usual highway speeds. I once got 22mpg on a long run but also once got 17 when I was running 75 for several hours....
You wont get much better unless you slow from 65. Biggest difference you can make is in tire selection. Some tires really do do better than others.
But the OP may have a need for speed. He might not want to be on lighter squishy touring tires. :p
As it sounds like your Pilot is pretty much getting some of the best gas mileage it can in it's present form, here are some mods (applies to any vehicle, not Pilot specific) that can help improve MPG: 65+ Efficiency Mods
Some additional tips / changes in behavior to squeeze out more MPG: 100+ Hypermiling Tips
There's a garage here that advertises a "induction cleaning service"
Anything to this?.
Super Moderator
Anything to this?.
Depends on the service. If it is one of the power clean services such as BG or the one Honda uses then yes they can be helpful. They inject the cleaner into the engine under pressure. With BG there is a follow up can that is poured into the gas tank at the first fill up after the service.
If it is just slowly pouring a can of some cleaner such as Seafoam, you can do that yourself.
1 - 19 of 19 Posts
