Forum Discussions about this Product
    1. · Registered
      I did not replace fitting on the cta tool. Just attached vinyl tubing to it and secured with clamp. On other end of tubing is barb included in Merlin kit (link below). It attaches perfectly to Motive (use some teflon tape).
      https://www.harborfreight.com/search?q=3/8 air hose repair kit
      I could not find the fitting to replace the one on the tool side and my 3/8” vinyl tubing would not fit over the fitting, even when heating it, too rigid. Instead, I used 3/8 silicon tubing and that worked perfectly.
      heres the fitting I used on the power bleeder side
      and hose clamps
    2. · Registered
      2019 EX AWD
      and hose clamps
      I used EZ-FLO-3-8-in-Inner-Diameter-x-10-ft-PVC-Clear-Vinyl-Tubing/1000365031 I bought at Lowes and no issue at all (I dipped the end in hot water for few seconds). Clamps and barb was included in Merlin kit. I wonder if the one you bought has the same thread as mine. The one that I bought is 1/4-in 18-NPT thread (according to HF) and It was pefect match.
      https://www.lowes.com/pd/EZ-FLO-3-8-in-Inner-Diameter-x-10-ft-PVC-Clear-Vinyl-Tubing/1000365031
Forum Reviews
Be the first to review this product
Write a Review
Do you have experience with this item? Help our community members and share your knowledge.
Sign in to add review
