Forum Discussions about this Product
    1. · Registered
      Home of the 306k 2012 V6 Honda Crosstour
      I dont deal with cold temperatures. But when I see this, I worry that their may be antifreeze leaking into the oil. Is their any signs of milkshake when you drain the oil? Is the coolant level dropping at all?
      P3400 code may require you to replace the vtec assembly. The filter screen may be clogged.
      Amazon also sells just the gaskets and screens. One negative review.
      Reactions: briantii
    2. · Registered
      Discussion Starter · #6 ·
      many thanks for all the replies!
      Gunk, amsoil, and motor medic make a motor flush. I'd try those before spraying the port. Probably wouldn't hurt to take a couple hour trip as well. That alone might break down what even is in there
      I'm going to try one of these cleaners. A few days after I changed the oil, I took her on an afternoon adventure and drove for a few hours. This fault happened a week or so after that.
      No signs of milkshake in the oil that I drained. It was black. And the coolant level is steady. So, no signs of head gasket leakage. I hope I don't have to replace that VTEC assembly :oops:
      Not sure if I'll disable the VCM. I might be getting a different vehicle this summer. I'd really like a truck for towing our camper. The Pilot can do it, but it's not ideal. Love the Pilot for everything else though!
Forum Reviews
Be the first to review this product
Write a Review
Do you have experience with this item? Help our community members and share your knowledge.
Sign in to add review
