I got this model last year, and just transferred it to my Pilot today from my '99 Blazer, where it had been less than discretely wired and had met with a rather low WAF :twak:. Stuck a 32GB microSD flash card in it. Also has Bluetooth for my phone.
Ran the wire up across inside the headliner, then down the passenger side A pillar tucked in nicely behind the weather stripping, then in behind the glove compartment along that metal bar you remove to change the cabin air filter, then inside the center console side trim, and it finally resurfaces just beside the not a cigarette lighter switched 12v power outlet near the not an ashtray. Not quite hardwired, but discrete, switched and versatile enough, and most importantly, passes the WAF. :31:
