2018 EX-L AWD w/Sensing 6AT, ATF cooler, full sized spare
My 2018 EXL did not come with courtesy lights nor did it come with running boards. I'm clumsy, my parents are getting older and my kids will be kids so I wanted lights for our safety. After searching for aftermarket help and finding nothing reasonable as usual, I decided to just do it myself. This is literally my second time soldering and just like to say that the crap coming out of my kids nose looks far better than my actual soldering. There are different and better ways to do this. This is just how I worked it out.
Looking at the back of the front door card reveals that there are no provisions for a courtesy light. I researched and cross-referenced parts that would make it happen and realized that it would take too much money and effort. So searching through this forum I found my golden ticket...
Inspiration
SOLDERING REFRESHER
Waterproofing LED strip
FINISHED PRODUCT IN ACTION
Parts used (not sponsored I paid for everything):
Shop around for these parts. I looked at several sites before buying.
EBAY
running boards (anyone that fit will do)
HONDA
Part # 32755-TK8-A00 x2 SUB-WIRE, FR. COURTESY LIGHT
Part # 08E12-TG7-10030 x2 HARNESS, STEP ILLUMINATED
Part # 08Z86-020-200 x4 MINI LOW PROFILE FUSE, BLADE 2A (can be a pain in the butt to find)
Part # 34262-SDA-305 x2 LENS
*Download the installation guide for the door sill trim before starting, as reference.
SUPERBRIGHTLEDS.COM
Part Number: WP18-2CMR x40ft PVC Jacketed 18 Gauge Wire - Two Conductor Power Wire
Part Number: STW10-EC2H x16 12mm Silicone Wiring End Cap
Part Number: WFLS-GL1OZ x1 Waterproof Sealant Tube
Part Number: EC10 x6 10mm Silicone End Cap
Part Number: STW-A65K90-C3F-10B5M-12V x1 5m White LED Strip Light 12/24V - IP67 - Cool White 6500K
Part Number: 194-CWCOB1W x2 194 LED Bulb - T3.25 Miniature Wedge Base - 135 Lumens - Cool White
Part Number: STW-2FPT-50 x2 Single Color Cable to Cable Connector - 0.5m - Female Connector - Waterproof
Part Number: STW-2MPT-50 x2 Single Color Cable to Cable Connector - 0.5m - Male Connector - Waterproof
AMAZON
100 Pack LED Strip Light Mounting Brackets Silicon Fixed Clips for 12mm Wide IP67/68 Waterproof Strip Lights
25ft - 1/4 inch PET Expandable Braided Sleeving – Black – Alex Tech Braided Cable Sleeve
OWN STUFF
Soldering iron and holder
Leadless solder
Brass wool
Helping hands w/ magnifier
Auto Wire Stripper
Lighter/torch
Heat shrink
Heat shrink butt connectors with solder
Heat gun
bricks or books
Folding table
Drill and driver
Food, drink, music
Understanding significant other (highly optional)
Wires and LED strips measured and cut before boogering
Testing w/12v battery from cordless ratchet
First time connected to Pilot (buy extra fuses)
Wiring the courtesy lights
Through the door batting
Under the speaker and then the glass
Through the flange
END PART 1
Inspiration
SOLDERING REFRESHER
EBAY
HONDA
SUPERBRIGHTLEDS.COM
AMAZON
OWN STUFF
Leadless solder
Brass wool
Auto Wire Stripper
Lighter/torch
Heat shrink
Heat gun
bricks or books
Folding table
Drill and driver
Food, drink, music
Through the flange
END PART 1
