I could not find the fitting to replace the one on the tool side and my 3/8” vinyl tubing would not fit over the fitting, even when heating it, too rigid. Instead, I used 3/8 silicon tubing and that worked perfectly.I did not replace fitting on the cta tool. Just attached vinyl tubing to it and secured with clamp. On other end of tubing is barb included in Merlin kit (link below). It attaches perfectly to Motive (use some teflon tape).
https://www.harborfreight.com/search?q=3/8 air hose repair kit
3/8" ID Silicon Tubing, JoyTube Food Grade Silicon Tubing 3/8" ID x 1/2" OD 10 Feet High Temp Pure Silicone Hose Tube for Home Brewing Winemaking: Amazon.com: Industrial & Scientific
www.amazon.com
heres the fitting I used on the power bleeder side
Amazon.com: 2 Pack Brass Hose Fitting, Adapter, 3/8" Barb x 1/4" NPT Male Pipe : Industrial & Scientific
www.amazon.com
and hose clamps
Amazon.com: Hose Clamp, 20 Pack Stainless Steel Adjustable 6-12mm Size Range Worm Gear Hose Clamp, Fuel Line Clamp for Plumbing, Automotive And Mechanical Application : Industrial & Scientific
Buy Hose Clamp, 20 Pack Stainless Steel Adjustable 6-12mm Size Range Worm Gear Hose Clamp, Fuel Line Clamp for Plumbing, Automotive And Mechanical Application: Clamps - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
