Hey folks,
I've got a 2005 Honda Pilot. 120k miles.
5 months ago took it in for Power steering pump (whining loudly). Was told high pressure hose needed replacing as well. Total cost about $800.
Now, coming up to this past week, took unit in for 100k (120k I'm a bit slow) maintenance items, including most fluids (Brake, Coolant, Transmission no PS since that was done earlier), tuneup (6 cyl) and timing belt.
Asked them to look at the power steering just because it still made a noise, just not near as loud as in past. Total cost for all services was $1900.
Got the car back, but the power steering was very hard/sluggish in use. I took it back, and they replaced pump (twice) and decided it was good (don't even get me started on why they didn't determine a PS issue when all the above work was done).
I test drove it, and although not quite as bad, it still was responding poorly. They felt it is within specifications of how it should feel.
Took it back anyhow, and they called back, telling me they could only tell that there might be some issue when turning sharply at a very slow speed. Their opinion is it is the control sensor in the Rack and Pinion, and I would need to replace the R&P (since the control sensor is not replaceable by itself). $1000 (Dealer wants $1800). Suggestions?
I feel I am a bit stuck since I have no other ideas or solutions to go with. My biggest concern is if I get this back, and it is still doing it, I may still have no recourse. Obviously I would argue a refund.
Thanks in advance for any advice.
James
James
