Trailer wiring harness brake fuse? - Honda Pilot - Honda Pilot Forums
post #1 of 8 (permalink) Old 03-27-2013, 12:21 PM Thread Starter
My driver's side brake light on my boat trailer just went out. I replaced it with another brand new LED light and it still doesn't work. I've verified the brake light itself is not getting any power, so now I'm looking at the truck. Where exactly is the trailer wiring harness fuse located? I have the OEM towing package that came with the truck when I bought it new. Is there a fuse in the rear left panel compartment? Or are their trailer harness fuses located in the subfuse box under the hood in the engine compartment?
bman5150 is offline
post #2 of 8 (permalink) Old 03-27-2013, 01:52 PM
If the right side still works and the left doesn't then you have a wiring problem not a fuse problem. If it were a fuse then the right side wouldn't work as well since both brake lights are typically on the same fuse. Look for a broken wire or exposed wires somewhere on the trailer. If you're running a 4 wire connector then the wires will tie together at the connector or somewhere on the trailer. If you're running a 7 pin connector then there are separate left and right pins but it just depends on who originally wired the trailer. Start by checking the pins on the vehicle for power when you hit the brake. If you have power there then you know its somewhere between the connector and the lights.
spray004 is offline
post #3 of 8 (permalink) Old 03-27-2013, 02:25 PM Thread Starter
Thanks spray004. You are right; I just looked over my Pilot owner's manual and didn't see any fuse listed specifically for the "driver's side" brake lamp. The truck's lights all work properly. Furthermore, there are only 3 trailer harness-specific fuses I can see - none appear specific to the stop lamps.
Usually these kind of things end up being pretty simple, so I'm going to go back and check my trailer's harness adapter. The trailer came with a straight 7-pin harness and I purchased an adapter for direct plug into the Pilot's harness. My guess is I might have an issue with the adapter or maybe even the trailer's harness. Possibly corrosion. I'm hoping it's not a wire short...major PITA to locate these when a good portion of the wiring is inside the trailer frame rails.
Wouldn't it be odd for me to have a short though specific to one single light on the trailer and to NOT be blowing any fuses? This is another reason I'm checking the 7-straight pin to oval adapter first.
This is helpful - thanks for your input.
bman5150 is offline
post #4 of 8 (permalink) Old 03-27-2013, 02:43 PM
I've never had any good luck with the 7 pin to 4 pin adapters for whatever reason. Are the frame rails C channels or tube rails? If they're just C channels you can crawl under the trailer and follow the wires usually and look for issues. It is uncommon for an exposed wire not to blow a fuse when it grounds itself but can happen I suppose.
spray004 is offline
post #5 of 8 (permalink) Old 03-27-2013, 03:41 PM Thread Starter
My flat 5-pin trailer harness uses a round 7-pin adapter to plug into the truck. Looks something like this:
Adapter 7 Pole to 5 Pole Flat - Molded Optronics Wiring A75TB
The trailer is rectangular but tubular, with a few drain holes ever few feet or so. The more we discuss this the more I'm convinced it's just corrosion or an issue with the adaptor. Easy for me to check this so that's what I'll do.
Also forgot to mention - it's a 5-pin becasuse I have surge brakes on the trailer - the extra "pin" is to lock out the brakes when I put the truck into reverse for backing.
bman5150 is offline
post #6 of 8 (permalink) Old 03-27-2013, 04:07 PM
RSQ Pilot's Avatar
Garage
Have you tried a voltage tester or test light for continuity in the wiring/connections from the Pilot through the adapters to the brake light/turn signal contacts in the taillight housing or a try a non-LED bulb?
2009 Pilot Touring RES 4wd Mocha Metallic; OEM Premium Running Boards, OEM cargo tray, Weathertech Floor Liners, H-9 LB mod, Michelin Defender LTX M/S @ 82K, full size LTX spare w/OEM rim, AVS Bugflector II
RSQ Pilot is offline
post #7 of 8 (permalink) Old 03-27-2013, 04:14 PM Thread Starter
Will be testing those tonight or tomorrow.
I've tried standard and an LED stop lamp. Both work in the passenger side; both don't work on the driver's side.
I'll report back what I find.
bman5150 is offline
post #8 of 8 (permalink) Old 04-01-2013, 02:06 PM Thread Starter
Update
I verified that the truck plug was working just fine using a multimeter. It turned out to be a bad adapter and/or 5 pin straight plug on the trailer. Replaced the adaptor and original 5 pin straight harness that came with the trailer with a new round 7 pin for a direct fit into the truck's harness reciever - problem fixed.
Thank god it wasn't some short in the trailer somewhere! Much easier fix!
Thanks for your guideance.
bman5150 is offline
