I was changing my bulbs in the tail lights (swapping out the stock with LEDs) and I think I blew a fuse. When pressing the brake pedal the brake lights don't come on any "brighter".. My BIGGER issue is that when I start my Pilot, I can't put it into reverse. It's stuck in Park! Does anyone know what fuse controls the rear tail lights / brake lights on a 2013 Pilot? I think that's why I can't shift it into Reverse.... I'm pretty sure it's a simple fuse related issue. Is there a separate fuse that controls putting the Pilot in reverse?
Pull the LED bulbs and put the old ones back,
I'm guessing the LED are not dual "filament ", so the brake lights aren't functioning. Without that trigger, the shifter will not be released.
