2013 EX Tire Pressure Monitor - Honda Pilot - Honda Pilot Forums
Register Home Forums Active Topics Insurance Photo Gallery Garage Search Today's Posts Mark Forums Read Auto Escrow
Old 05-29-2013, 02:08 PM   #1 (permalink)
Default 2013 LX Tire Pressure Monitor
Folks, i'm so sorry for this newb question. I have Base 4WD LX model. I cannot figure out if it has a tire pressure monitor system and if yes, does it need any servicing, like battery change, etc.
Thanks in advance.
supplier is offline   Reply With Quote
Old 05-29-2013, 03:36 PM   #2 (permalink)
fossilkey's Avatar
TPMS comes in all models of Pilots.
2013 Honda Pilot - Specifications - Official Honda Site
2012 Honda Pilot 4WD EX-L - Bali Blue | CF Vinyl wrapped Grille | Interior LED Lights | Allen Deluxe 4-bike rack
2009 Infiniti G37xS Sedan - Blue Slate | Midnight Black Grille | Diode Dynamics Int. LED Lights
fossilkey is offline   Reply With Quote
Old 05-29-2013, 04:05 PM   #3 (permalink)
Originally Posted by fossilkey View Post
Thanks. The reason i asked as friend of mine just had sensor failure due to drained battery (2005 RAV-4). Had to replace 5 sensors at $120 each plus labor. Does Honda Pilot requires any sensor/battery change over the time?
Old 05-29-2013, 04:43 PM   #4 (permalink)
TPMS started in the 2005 model year, I believe. The sensor has a battery in it and it will fail someday, not sure when. Mine are still fine since 2005.
2005 LX 4wd
OEM accessory roof bars
OEM nerf bars
OEM rear splash guards
2006 OEM 4wd emblem
Garmin GPS
Aftermarket tinted windows
OEM accessory fog light kit
OEM accessory cargo cover
Silver painted grill
Acura stainless exhaust tips
KYB GR2 struts/shocks
Curt 13328 Hitch
Old 05-29-2013, 10:16 PM   #5 (permalink)
Most decent tire shops will replace the battery via a "kit" when you replace your tires. Of course, there is a charge. Typically, under $10.
RinconVTR is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
