#31 (permalink) | |
Reading over the posts, I appears some believe I'm saying that air bags will have the same weight distribution as a WDH. I am not, and have not said that, at all. Air Bags are in fact intended just to reduce a sagging rear and a front end pointed skyward. Air Bags and WDH actually work great together (that's why I installed them!!!) but they do not have the same effect. We repeatedly get stuck on "weight distribution". I have said and shown that there is a very small weight change rear to front with a air bags. The actual amount could hardly be called "weight distribution" because it is so little. Its almost meaningless, but not zero either. In hind sight, was it a good idea to drag down the thread to debate a small weight change? No. |
#32 (permalink) |
Why don't you draw a simple diagram, and you will see that the angle does not change enough to significantly move the fulcrum rearward as would be required to effect the load shift to the front axle that you predict.
You do not need to know the weights, just make some up because the principles in play are there no matter what the weight is. Just for Sh!ts and grins, use the dry weight of the pilot evenly split between the front and rear axle by either placing 1/2 over the rear and 1/2 over the front, or the whole weight at the mid point. Then add the tongue weight at any reasonable distance beyond the rear axle. Now the springs are relatively unimportant, as once compressed you have a static system. Break out the old text book and show me how under any conditions any significant amount of weight is transferred to the front axle based on the height of the rear fulcrum.
#33 (permalink) | |||||
Second, "What we have here is a FAILURE TO COMMUNICATE!" You say "significant", while others cant leave WDH alone, all the while all I consistantly say "small", "some" and "slight". Quote:
In my line of work, real world tests ALWAYS trumps calculations. But I did take a glance at the only books I kept from college here at work. They were last "used" in 95 and 96! I'll be honest, even if there was a fitting example that I could easily plug numbers into, it would take me hours to run the equation after so many years, and then I'd need another engineer to verify it. That's not happening.
#34 (permalink) |
Yes, we have a failure to communicate.
You are (as always) right, and the rest of us are wrong. Feel better?
#35 (permalink) |
Hi folks. New guy here. This topic here is exactly why I joined the forum. I just bought a 2012 Pilot Touring (well, my Wife's Pilot to be exact).. anyhow, I already own a travel trailer that I pull with my Power Wagon, but it is too large and heavy for the Pilot. My kids LOVE LOVE LOVE the Pilot, but HATE riding in the Power Wagon. So my plan is to "Downgrade" my travel trailer to a smaller lighter one that the Pilot can tow. I would prefer to leave my Pilot stock, as it is mainly my wifes but we would like to tow a small camper for camping and soccer tournaments. Any suggestions as toa good size/weight/brand? THANKS!!!!
#36 (permalink) | |
#37 (permalink) | |
#38 (permalink) | |
In short, it was ridiculous to take over a towing thread for this! |
