#61 (permalink) | |
Reality is these engines have been sold by the hundreds of thousands identically equipped, and failure due to oil has been in the 10's... Evidence is anecdotal and far and few between. Personally I change all my oils earlier than recommended and I wont own the Pilot anywhere near the mileage that the belt will need replacing (leased), but I would change it earlier than 100k for good measure. Sent from AutoGuide.com Free App |
#62 (permalink) | |
Has Honda tested engines for at least 100K miles, operating mainly in cylinder deactivation mode and with oil changes only every 10K miles? Who knows, but one would hope so. The few and far between reports seem to correlate with long OCIs and driving conditions that would cause frequent operation in cylinder deactivation mode. Maybe it depends, as well, on the particular brand and type of oil used. |
#63 (permalink) |
Follow-up:
Changed the oil last week for the first time, with maintenance monitor showing 50% life remaining. About 4k on the car at this point, 1k of which is mine. The oil that came out was dark caramel color but no black. Black would be a telltale that there's possible misfire/blow-by, etc. I don't know what kind of oil that Honda installs as factory fill, so no clue what the original oil looked like when it went in. The "real test" is having a used-oil analysis done, but that's not in my plans at least for a while. New oil is Mobil-1 0W-30. Installed a Fram filter but will probably order Honda filters for the next round. I was somewhat surprised at how tiny the filters are. So I opened the Fram online specs list for their oil filters, with an eye towards finding a filter with similar mounting and gasket dimensions, same relief pressure, anti-drainback valve, and maybe a larger canister. There are none shown that are exact, but... The other car in my side of the garage is a Porsche 928, for which I stock filters etc. The 928 oil filter has the same threads 20x1.5, 13 PSID bypass valve relief pressure, and has the anti-drainback valve. The mounting gasket is one gasket-width larger than the Honda filter. So at next oil change, I'll measure the mating face on the Honda and see if it's large enough to accept the other filter safely. The Mann filters we use on the Porsche V-8 hold just enough more oil so that the full 5qt jug can go in the Honda engine. The filter construction is a lot more industrial-strength than the Fram, with solid caps, an extra fabric layer (so 2 fabric, one cellulose), for better filtration down to 6 microns. I'll alert the group when I do that next oil change, likely late in this year.
dr bob 2013 Touring Glendale, CA (Los Angeles area) |
#65 (permalink) |
hit 10% @ 8500 miles and called for an appointment with Honda, then took it in a few days later... they changed the oil, rotated tires, topped off all fluids and checked for the recall. mine was fine.
with the 8yr/ 120k mile Honda warranty, that's all I plan (hope) to do for many years to come.
#66 (permalink) | |
Royal Purple has one of the best filters around, number of the S2k filter is 10-2808.
2012 Pilot 4WD Touring - PMM 2010 Pilot 4WD Touring - White - Traded 2005 Acura TL - SSM 2000 Acura TL - Totaled 2004 Jetta GLI - Sold |
#67 (permalink) | ||
----- I had to add a little extra tightening torque to the Fram filter after noticing a little dribble of oil from it. I used the basic "contact plus 3/4 turn" strategy originally, but it needed just a little more than that. I'll be monitoring that some more I guess. The factory filter was on there a lot tighter than I expected, so maybe it's a function of thread pitch. I'll get a better look at the mounting face next oil change I do. Plan now is to let the dealer do the "scheduled" changes to maintain an 'official' maintenance record. I'll do the tweener services myself. Thanks for all the tips!
#68 (permalink) |
The Royal Purple filter is a Mobil1 filter, with the nut end on the corner.
If you want a great quality built filter the Bosch Distance+ I purchased last time was top notch. Sent from AutoGuide.com Free App |
#69 (permalink) | |
The Tough guard also has a (supposedly superior) silicone rubber anti-drainback valve compared to the nitrile rubber valve in the Extra guard. The Honda by Fram filter looks very similar to a Tough guard. Before you buy the Mann fitment for a Pilot, see if appears to be as well constructed as the 'Porsche-grade" model. If the dealer will be performing the scheduled oil changes, ask them to use the S2000 filter. The P/N is 15400-PCX-004 and it's still made by Filtech (Honda's Japanese OEM supplier). It doesn't use the cardboard endcaps like the Honda/Fram filter and seems to have superior construction, based upon cutaway views. FWIW, it's also significantly heavier. Pick up an extra one (and a crush washer) for your "tweener services" when you're at the dealer for scheduled maintenance. |
#70 (permalink) | ||
Champion labs makes both the mobil1 filter & the royal purple one and K&N as well, but I think the royal purple is a step up. It uses 100% synthetic media where the others are just a blend.
#72 (permalink) | |
Does this mean it may not fit on the Pilot, or could cause problems if used? I'm getting ready to order the Honda synthetic oil and a filter, and I like what some folks here have written about the S2000 filter, but the Bernardi comments have me worried. Thanks. |
#73 (permalink) | |
#74 (permalink) |
What is the benifit of using the S2K Oil Filter?
Size ? Construction? Also if I want to switch to Synthetic, what oil grade should I use? I currently own a 2012 Pilot EX-L
2012 Pilot EX-L RES - Current 2009 Honda CRV - Current 2000 Honda S2000 - Current 2006 Lexus IS250 - Sold 2003 Honda Accord Coupe V6 - Sold 1992 Honda Accord - Sold Last edited by G007; 03-14-2013 at 02:18 PM. |
#75 (permalink) |
Same as if you were running conventional.
2012 Honda Pilot Touring 4WD - Diamond White Pearl/Black leather 2011 Dodge Challenger R/T - Green with Envy, 6MT Last edited by Yahooligan; 03-14-2013 at 03:00 PM. |
