My 2009 Honda Pilot only blows cold air when the heat is on. I'm hoping to find something I can fix myself other than a bad heater core, which would be a costly replacement. Can anyone tell me where these parts are located?
plplplpl 14580 posts · Joined 2015 Add to quote Only show this user #2 · Jan 7, 2016 I have no idea whether it's the same in a 2009, but if it's like for earlier models you might want to try the infamous rusty/jammed heater valve on the passenger side just near the firewall. If that's all it is, at least it's an inexpensive and easy fix: http://www.piloteers.org/forums/14-problems/22415-no-heat-front-console-5.html#post967754
golftango 860 posts · Joined 2014 Add to quote Only show this user #3 · Jan 10, 2016 From what I'm reading that valve is not on the 09-15 Pilots, or they don't know where it is.
T thej1rk Discussion starter 3 posts · Joined 2015 Add to quote Only show this user #4 · Jan 10, 2016 Thanks. That's the conclusion I've reached.
poorman212 378 posts · Joined 2015 Add to quote Only show this user #5 · Jan 10, 2016 Is this the dual control (can set drivers side temp different than pass side) or single control? Either way I would look into testing the "mix motor" for the HVAC. There should be a "self diagnostic" function on the HVAC unit - sorry I don't have the service manual for the '09, just the one for the 06-08.
