2011 Sporadic transmission Shudder - Honda Pilot - Honda Pilot Forums
post #1 of 15 (permalink) Old 01-30-2013, 10:14 AM Thread Starter
desco's Avatar
Hi, I have been experiencing the infamous Honda transmission shudder in my 2011 PILOT EXL.
Happens on light throttle between 25-40 mph. If I throttle up or down the shudder disappear. The problem started at 37,000 km. Went to dealer sure I could replicate it but I could not.
Before the test with a technician the car was parked at the dealer in an incline, then I could replicate it until next day.
Dealer checked fluid level and color/smell and it was within spec.
Read some forums and many indicate problems in the 3 and 4 pressure switch getting out of tolerance.
Bought the 2, 3, 4 switches changed the 2 and 3 and the problem seems to be gone ( I haven't been able to replicate it).
What gets my attention is that the old switches are within spec. (Built my own pressure switch tester with an air pump, continuity tester and tubeless tire valve).
2 & 4 on @ 27 psi off @ 17
3 on @ 33 psi off @ 23
Have been reading about Lubegard Red, it even is mentioned in a Saab service bulletin as the cure for shuddering.
desco is offline
post #2 of 15 (permalink) Old 04-12-2013, 11:14 PM
My 2011 shudders also. Recently, on a highway when i had to accelerate quickly and pass a car, my car hesitated so badly that it could not "find" the right gear and it was a very uncomfortable feeling - scary until the car started moving.
Pilotman123 is offline
post #3 of 15 (permalink) Old 04-13-2013, 10:29 AM Thread Starter
desco's Avatar
After changing the fluid switches the issue repeated again, car went to the 40K kilometers scheduled maintenance and as part of the maintenance the ATF was changed, Wonder if they used the new ATF DW1.
So far the shuddering seems to be one.
desco is offline
post #4 of 15 (permalink) Old 04-17-2013, 08:12 AM
Check on your invoice to see if they did the PGM software update.
2009 DCP Touring, Navi & RES
2008 Ducati 1098 R.I.P.
moda_way is offline
post #5 of 15 (permalink) Old 05-27-2013, 06:38 PM
Quick update...I drove this all weekend on the highway mostly and it is an apparent issue. Bucking/hesitation when ECO/VCM kicks on...the light kicks on going 80 MPH??? I shouldnt even notice a lack of power. Called the dealer and made another appointment to get this checked out. They are oblivious to the PGM updates or anything else going wrong with Pilots...they claim they never see it...BS. I am also calling American Honda tomorrow to get on this. This is outrageous. I am not getting stuck with a 1 owner 2011 with 19500K miles on it giving me vibration and bucking problems. Did anyone else call American Honda and report this?
recruiter is offline
post #6 of 15 (permalink) Old 10-31-2016, 04:35 PM Thread Starter
desco's Avatar
Shuddering gone after replacing 4 qts atf with Dw1 new aft
2011 Honda Pilot EXL The best vehicle to keep a DIY busy and Honda autoparts selling...
2011 Honda Pilot EX-L ---2 set of front struts, 1 steering column, 1 rack & pinion, 3 sets of compliance bushings...and now rear engine mount) This will be my last Honda.
desco is offline
post #7 of 15 (permalink) Old 01-10-2017, 05:34 PM
Hi desco: Has the problem gone away completely? DW-1 fluid is standard at my dealership and it's what I put in myself at 30,000 miles. So, I am on fluid batch #3 after the dealership changed it at 70,000 and its all DW-1, yet the problem happened this week when the cold front came through after turning a corner and while going about 25-30 mph. Not sure that the fluid is the solution. Thus my question.
Walkthewalk is offline
post #8 of 15 (permalink) Old 01-10-2017, 05:50 PM Thread Starter
desco's Avatar
Yes, my shudder dissapeared completly. A month ago I did the third change of 4 qts.
desco is offline
post #9 of 15 (permalink) Old 01-10-2017, 06:35 PM
Super Moderator
Rocky's Avatar
If your Pilots are operating on less than six cylinders, would be interesting if the vcm muzzle stopped the shudder.
Rocky is offline
post #10 of 15 (permalink) Old 01-11-2017, 02:10 PM
My 2009 EX-L had a similar problem, felt vibration between 35-45 mph, level road surface and light throttle. Almost felt like running on road rumble strips.
I left it at the dealer for four days, insisting that they keep it until they're able to reproduce the problem. I had 96,000 miles at the time and I wanted the problem fixed before warranty ran out at 100K. The service manager finally managed to reproduce the problem and attributed it to a faulty torque converter, replaced under warranty. Pilot now has 108,000 miles and the problem is gone! I hope for good
Tom
tcontic is offline
post #11 of 15 (permalink) Old 02-16-2017, 09:08 PM
same here with the shudder
i bought a used 2011 pilot 10 days ago. during the test drive i did not notice the shudder, but once i got to town 2 hours later, i noticed it. between 35-40 miles per hour. wondering if the vcmuzzler II, along with changing the tranny fluid to redline synthetic or the new honda w fluid will help, or changing out the 3rd and 4th gear solenoids will help. i'm a bit heartbroken that this vehicle i haven't even paid a month on is already compromised. the local honda guy thinks it's the torque converter, but says to get a second opinion. i have an appointment on monday at a very reputable honda shop.
davebaer is offline
post #12 of 15 (permalink) Old 02-16-2017, 09:22 PM Thread Starter
desco's Avatar
Please Only change the Transmision fluid, do Not touch the pressure switches and forget about the other things they tell you.
I tried everything and what ended the shudder was to change the fluid for the DW1 honda fluid.
desco is offline
post #13 of 15 (permalink) Old 02-16-2017, 09:28 PM
i see you've been posting for years, desco. did you deal with the shudder for years? is the transmission fine? would you tow a trailer now?
davebaer is offline
post #14 of 15 (permalink) Old 02-16-2017, 10:27 PM Thread Starter
desco's Avatar
Tranny is ok, I notice that the change of fluid made the car quicker... More responsive. The more fluid changes you make, the less old fluid will be in the system. After the first fluid change the shudder seemed to come back two years later so I did a new change. By now I think all the old fluid is off the system.
What I think is that many 2011 were born with the old z1 fluid and some with the dw1.
There must be a reason as to why honda switched to a new ATF... Don't you think?
desco is offline
post #15 of 15 (permalink) Old 02-17-2017, 10:53 AM
MM just came up with a Tranny fluid change on my 2011 this past week. Did the change last Sunday and my perception (I know, hard to measure or quantify) is that the Pilot is more responsive and shifting smoother. Fluid was not overly discolored nor did it have any foul odors. Debris adhered to the drain plug magnet was at a minimum as well. I believe I was around 14 months between this and my last change. Not a lot of miles, but a lot of towing this past fall and winter so I'm not surprised that I was due. I only did one change this time and that was with DW1. My goal is to do the ATF changes on an annual cycle at a minimum. Overkill maybe, but for the cost of 4 quarts of fluid, it's not gonna hurt anything.
Other than the cleanup from dropping a full bottle of ATF all over my transmission, it is an easy process. This time it took an hour with cleanup. Normally 30 min.
2016 Accord EXL, White Orchid Pearl
2011 Pilot EXL AWD, Grey
2008 CRV EXL AWD, Tango Red
2009 Lucerne CXL,
Johnjk is offline
