2011 VTM-4 light - Honda Pilot - Honda Pilot Forums
Old 01-23-2013, 10:42 AM   #1 (permalink)
Default 2011 VTM-4 light
I have a vtm-4 light that comes on once in awhile in the morning (first startup). Once I cycle key after light is on it goes away. Idk if its cold bit it's been under 20 degrees here in MN. Any input would help. Oh I have a Compustar remote starter.
leosaw978 is offline   Reply With Quote
Old 01-23-2013, 10:12 PM   #2 (permalink)
Recently had the same issue with my 2011 and it was occurring after engaging the auto-start. Had the dealership check it out during the last service, it was found as per the codes the battery was giving out low voltage. Honda replaced the battery.
Possible you having the same issue the battery could be drawing during cold weather start ups.
Sully2011 is offline   Reply With Quote
Old 01-24-2013, 10:43 AM   #3 (permalink)
rocky's Avatar
Similar feature affects first gen Pilots too. Report to the dealership at next service.
Old 01-24-2013, 01:29 PM   #4 (permalink)
Did it go away after the batter replacement?
I do my own work since I use to be a Honda tech. Nevr seen this issue since I was there.
