So I finished the A13 code oil change, but the manual also states to chage Transfer Fluids. What are these? ![]() TIA
'09 Touring 4x4, Nimbus Grey with Black interior, Rear Entertainment, Dark wood trim all around, Lighted side step, Chrome Grill, Aluminum front and back under side, Window guards, All weather floor mats!! |
Sub code 3 is ATF and Transfer case fluid, fill and drain ports are along side the transmission housing... see pg 484, 2009 OM. Easy drain and fill. Make sure fill plug brakes loose before trying the drain plug...gl 4 or 5, 80W90 or 90Wfluid about a half a quart.
How do u know you have enuff fluid in ?? I'm assuming you can put to much ?
Sent from AutoGuide.com App |
Transfer case is simple, fill into side port until fluid starts to spill out makeing sure that axle is level (e.g. not jack up on its side.)
2009 DCP Touring, Navi & RES 2004 Acura TSX (bunch of mods b/c its fun) 2008 Ducati 1098 R.I.P. |
