2011 Pilot Compliance Bushings - Honda Pilot - Honda Pilot Forums
post #1 of 13 (permalink) Old 10-10-2012, 01:17 AM Thread Starter
Garage
Smile 2011 Pilot Compliance Bushings
Hello All,
I just had my Pilot in the dealer (Earnhardt Honda in Avondale, AZ). Brought it there Sat morning to have a wheel alignment done because I had just installed new tires. Michelin LTX MS/2 (255/65/17) Found out that the front compliance bushing were bad. 42000miles and I actually had noticed one of them leaking in my garage a few weeks ago. Did not know these bushings were oil filled till dealer told me. Anyway, dealer wants $637 to replace the bushings (parts included) plus $120 for an alignment. I checked into doing it at home and decided not to. Dropped it back at the dealer this week and told them how I saw many other Pilot owners having the same issue, complained about there not being a recall or TSB on the topic specifically. I also mentioned that I know the new parts have been updated so Honda knows about the issue. All in all the dealer did me a solid. The service writer Chris S. went to bat for us with Honda and got the warranty dept to split the bill with me. Out the door for the bushings changed and alignment with tax (10% in AZ) was $417. I was happy with the service at Earnhardt Honda and I still love my Pilot. Thanks Chris.
I should mention this is the 3rd major issue with this vehicle. At 5k miles we found the propeller shaft (hanger bearing) bolts were loose. One bolt was missing completely and one was backed out about half way. Same dealer fixed it no problem. At 15k found the left front wheel bearing was shot and making a lot of noise. Dealer repaired under warranty and did an alignment. Still love the Pilot (nicest car I have owned so far and the first SUV as well). I want it to last for many years after I have paid it off. Hope this is it for a while.
Anthony496 is offline
post #2 of 13 (permalink) Old 10-10-2012, 08:28 AM
Sounds like you got a good deal, it's unfortunate that this bushing problem is as bad as it is for Pilots that are only 2 years old. How long until we hear about a wave of 2012 owners with bad bushings just out of warranty?
Anyone know what model year has the updated parts?
My 2010 is in the shop right now for this problem...
2010 Honda Pilot EX - Polished Metal Metallic
rjackal is offline
post #3 of 13 (permalink) Old 10-10-2012, 12:43 PM
Super Moderator
Rocky's Avatar
Bushings or engine mounts. Bushings are rubber and metal. Engine mounts have fluid in.
Sounds like dealer doesn't know what they are talking about
Rocky is online now
post #4 of 13 (permalink) Old 10-10-2012, 03:04 PM
Rocky, please see this thread for more complaints about the same issue on '09-'11 Pilots, along with pictures. There is clearly fluid leaking out of these control arm (compliance) bushings.
Wheel and Brake vibration - lower control arm bushing
rjackal is offline
post #5 of 13 (permalink) Old 10-10-2012, 04:38 PM
Our 09 pilot is now at 110k miles. About 15k miles or so ago we finally solved the steering wheel and brake shutter problem by replacing both of the compliance bushings and I had the replaced rotors turned for piece of mind (I replaced the stock rotors initially thinking they were warped - the replacement ones were not warped). They (the compliance bushings) are fluid filled (Rocky, you sound like the service guys at our Hardin Honda stealership - man, I hate that place) and in the early 09's they are a different design. I did the work myself and separating the lower control arm from the steering knuckle wasn't too difficult, but I pierced both the steering knuckle boots - which they do not sell replacements for unless you buy the entire aluminum lower control arm for some gawdawful amount per arm (I found that a '68 Chevy Nova steering knuckle boot fits pretty damn well).
We almost pulled the trigger on a low mile used 2011 Pilot last night ($24k, $1k down and lower payments - and it was silver with black leather instead of this "show all the dirt grey" and beige leather we have now) until I read this post. Sigh. I guess we'll wait to pay this sucker off, continue to drive the wheels off of it and trade it in on another 4Runner. We'll see when the "new" bushings go out. Oh, my letter to American Honda was met with a very pleasant "sorry, we can't help." Bury your head in the sand, Honda. We bought our last of your vehicles . . . .
2003 Toyota 4Runner SR5 V8
2009 Pilot EX-L
Shamus is offline
post #6 of 13 (permalink) Old 10-10-2012, 05:39 PM
mobro's Avatar
Shamus - I'm impressed that you did it yourself. That was my plan, Bought the parts and set aside a Saturday morning to do it. But once I saw that weird upside down ball joint I chickened out.
I'm with you on the disappointing quality. It was my goal to buy a brand new car once before I retired. Honda was the gold standard for quality in my mind. But it seems like every TSB that was published for Pilots were about a problem I was having, and then some that weren't discussed. Once the warranty expired I had to start deciding what to fix, and what to live with. I think Honda is being short sighted with the declining quality. The perception of their brand reputation is what allowed them to charge more. They are quickly spending the good will they built up over the decades.
mobro is offline
post #7 of 13 (permalink) Old 12-29-2014, 09:58 PM
My 2011 Pilot has 70K miles and dealership said both compliance bushings were bad. They called Honda and I will only need to pay $100 and Honda will cover the rest. I would check the bushings sooner rather than later. Seems to be a common issue.
VinceDigital is offline
post #8 of 13 (permalink) Old 12-30-2014, 12:31 PM
As a new owner of an 06 Pilot I first mus say that so far I like it. The down side is a $1400 timing belt, a $300 spark plug, expensive routinely used fluids, and now $700 wort of front end work. My last vehicle was an 05 Bonneville that I put 205 k on. Oils, tires, brakes. No timing belt, front end work,spark plugs or special fluids.
I will do the plugs on the Pilot and I think I can do the belt thing, fluids, now front end parts? Not sure if I can do that one. Just seems like a lot of expensive work that most people can't do themselves.
tunaboy is offline
post #9 of 13 (permalink) Old 12-30-2014, 06:28 PM
I forgot to add radiator replacement and having to adjust valve clearances.
Tuna
tunaboy is offline
post #10 of 13 (permalink) Old 02-04-2015, 06:04 PM
I have had two Pilots now and will never buy another one. They both have had terrible brake issues. I've had to have my new slotted rotors machined and my Pilot is shaking less but brakes are squeaking. Nothing but constant brake issues. Now at 70,000 miles my compliance bushings are bad and Planet Honda wants to charge me $900.00 to fix. I've never heard of compliance bushings. Can't wait to buy my next vehicle....it will be a Toyota.
jmorrissey is offline
post #11 of 13 (permalink) Old 10-19-2015, 08:50 PM
another compliance bushing failure. . .
reachme is offline
post #12 of 13 (permalink) Old 10-31-2015, 12:41 AM
Seems like Honda acknowledges their compliance bushing issue because I received a letter in the mail last month about extending the warranty for compliance bushing if they go bad. My wife's pilot has 66k on it on the same brakes, shocks and compliance bushing. Guess its hit and miss.
2011 Silver Touring 4WD Nav-Res
_________
U.S. Army 94-Present
gtbigup01 is offline
post #13 of 13 (permalink) Old 11-22-2015, 09:06 AM
Honda really stepped up for me.
Before doing it myself dealer diagnosed it at 120,700 miles-700 miles over TSB for $900. I told them about the bulletin and they should do it for free having ignored it in the past ( they had to rebuild lower end due to lubing issue a year ago). They told me to bring it back in so they could diagnose the "cause" of the failure to see it it is covered. I told them the cause is a bad part and TSB doesn't mention checking for cause.
They said if I didn't like it to appeal to American Honda so I did. American Honda paid 90% and dealer used all new arm, castle nut etc. looks great. I even paid for alignment I knew it would need.
Thanks American Honda for doing right even at 120k on a 2010 pilot!
reachme is offline
