Anybody experienced a total drain on your washer fluid tank? Because after filling my tank full, I was surprised that after 2 days it was fully empty. Any suggestions guys? Thanks.
![]() MY 2009 EX-L 4WD PILOT ONLY WITH ORIGINAL ACCESSORIES Honda Pilot OEM All Season Black Floor Mat Part No. 08P13-SZA-110 Honda Pilot OEM Cargo Organizer Part No. 08U20-S9V-101 Honda Pilot OEM Front Lower Trim Part No. 08P01-SZA-100 Honda Pilot OEM Back Up Sensor Kit Part No. 08V67-SZA-100A Honda Pilot OEM Cargo Dividers Part No. 08U45-SZA-100A Honda Pilot OEM Cargo Net Part No. 08L96-SZA-100 Honda Pilot OEM Cargo Tray Liner Part No. 08U45-SZA-100 Honda Pilot OEM Cross Bar Part No. 08L04-SZA-110 Honda Pilot OEM Door Visor Part No. 08R04-SZA-100 Honda Pilot OEM Front Aluminum Under Trim Part No. 08P46-SZA-100 Honda Pilot OEM Gray Cargo Cover Part No. 08U35-SZA-120 Honda Pilot OEM Hood Air Deflector Bug Guard Part No. 08P47-SZA-100 Honda Pilot OEM Moonroof Visor Wind Deflector Part No. 08R01-SZA-100 Honda Pilot OEM Premium Running Board Part No. 08L33-SZA-100B Honda Pilot OEM Rear Aluminum Under Trim Part No. 08P46-SZA-100A Honda Pilot OEM Seat Cover Second Row Part No. 08P32-SZA-100 Honda Pilot OEM Towing Kit Part No. 08L92-SZA-100 Honda Pilot OEM Trailer Hitch Ball - 1-7/8" Part No. 08L92-S9V-100G-9P Last edited by SAND STORM; 05-31-2012 at 09:12 AM. |
Fill it with water and look for a leak.
Washer fluid is just water mixed with methanol as a freezing point depressant. You can run just water in the summer time without any issue.
Owner of 07' LX 4WD Clarion NX500 w/ Backup Cam Pioneer 6.5" Speakers all around -OEM Fog Lights -Rear Mud Flaps -KYB GR2 Suspension -AEM SRI -245/70/R16 Cooper Discoverer A/T3 |
Could you see that it was empty, or was no water coming out of the windshield washer when you tried to spray the window? If I remember correctly, you can't see all the way to the bottom of the tank. You may be asking the wrong question.
That said, there's only one way and one way out of that tank. Check for leaks. Water is a great idea. ps. What's with the parts list? Just curious? pps. Welcome to the forum!
Current Vehicles: '11 Pilot LX 4wd; '10 Subaru Outback 3.6R; '02 Honda Shadow 750; Pilot v. Outback: http://ohmahdeehness.wordpress.com/2...-two-vehicles/ |
My 2009 recently started leaking too. I believe the leak is at the bottom of the tank because when I fill it, it takes the entire gallon. I filled right up to the top of the neck. Within 10 minutes it had gone down a few inches and I started to see the puddle on the ground. I think I'll have to pull the tank to see what is going on. I'll let you know what I find.
