Strang whine coming from the engine on cold starts - Honda Pilot - Honda Pilot Forums
Old 02-01-2012, 12:34 PM   #1 (permalink)
Default Strang whine coming from the engine on cold starts
Hi Guys,
Has anyone experience this issue? It's a 2009 Honda pilot. Here's the video
2009 Honda Pilot Strange whining sound on cold start up - YouTube
Thanks,
Jake
09 Pilot EXL taffeta white
Mods: premium running boards
Pilot09 is offline   Reply With Quote
Old 02-01-2012, 12:49 PM   #2 (permalink)
Love the R2D2 like sounds. My guess is that the accessory belt is not under sufficient tension, so as the engine starts the pulley moves before the belt.
If accurate (there are lots of other reasons) replace tensioner and belt.
Old 02-01-2012, 06:29 PM   #3 (permalink)
I would start by just removing the serpentine accessory belt and then starting. If the noise persists, then the noise is other than accessory related. If it goes away, replace the belt first or try a little bit of belt dressing just as a temporary test. If the noise still exists with a new belt then you may have a power steering pump, alternator, ac clutch, tensioner or idler pulley going bad. Look for simple things as well, like the PS fluid level.
2011 Pilot EXL 4WD, White
landar is offline   Reply With Quote
Old 02-01-2012, 08:24 PM   #4 (permalink)
I also have this sound. I think it is the PS fluid.
pilotman7 is offline   Reply With Quote
Old 02-01-2012, 11:37 PM   #5 (permalink)
I have the same noise on mine and have for two years or so. I've always just thought it was a cold start noise.
MavePilot is offline   Reply With Quote
Old 02-02-2012, 01:30 PM   #6 (permalink)
check PS fluid level is between the 2 lines on the reservoir
2011 Pilot EX-L 4wd Black on Grey
2003 VW Golf TDI GLS
robere is offline   Reply With Quote
Old 02-02-2012, 09:04 PM   #7 (permalink)
mine is between the min and max lines
Old 02-02-2012, 11:38 PM   #8 (permalink)
Arizonaadam's Avatar
Does it happen under any other circumstances? It's not making a classic belt squeal. If it only happens on cold start probably not the belt. But, easy test fix.
Old 02-03-2012, 11:57 AM   #9 (permalink)
I would try a PS fluid flush (i.e. drain and refill the reservoir twice, fluids cheap~$20 max) - If the problems still there, check with the dealer
Old 02-08-2012, 08:18 PM   #10 (permalink)
I'm having the same noise.
Sent from my Autoguide iPad app
2009 Pilot Touring 4X4
2006 Pilot EX-L w/nav (traded for 2009)
2006 MDX
2003 Pilot (traded for 2006)
twistedmuscle is offline   Reply With Quote
Old 02-08-2012, 11:16 PM   #11 (permalink)
Change the o-ring on the inlet line side of the power steering pump if you have foam in the fluid reservoir. Your sucking air, the new O ring will be red.
Old 02-09-2012, 09:44 AM   #12 (permalink)
agree with the others that it may be the PS fluid. i had it much more pronounced on a previous vehicle. the fluid was old and dirty, causing the pump to work harder to force it through. only happened when it was cold and the fluid "thickened" up some. had it replaced and never heard the noise again.
ant-ny is offline   Reply With Quote
Old 02-09-2012, 12:46 PM   #13 (permalink)
The p/s inlet o ring is a very common problem on the Honda's. It shrinks too much in the cold, allowing air to be drawn into the pump. The noise is from the air being purged from the power steering pump.
Even if you cannot do this yourself, it takes no more than 30 minutes to drain the fluid, replace the o-ring, and refill the system. If the dealer charges more than $75, they are overcharging you.
Old 02-11-2012, 11:40 AM   #14 (permalink)
Thanks for all the feedback. I still have 1500 miles left in my powertrain warranty, so I will take it in for a visit at the dealership and see what they find.
Jake
