TPMS question - Honda Pilot - Honda Pilot Forums
Old 01-09-2012, 11:56 PM   #1 (permalink)
Default TPMS question
Newer Honda and Acura TPMS are they the same will they work on my 09' pilot? Also the light on the dash , does the light go on if one of the tire pressure is lower then the other tires but not a flat tire?
bertuzzi is offline   Reply With Quote
Old 01-10-2012, 08:34 AM   #2 (permalink)
jeproks's Avatar
Not all. Look for these part #s 42753-STK-A04; 42753-STK-A03; 42753-STK-A02. Not sure what the threshold ft/lbs for lower pressure for the light to come on but yes, lower pressure on 1 tire will turn the dash light on.
2011 White Diamond Pearl Touring 4WD
jeproks is offline   Reply With Quote
Old 01-10-2012, 09:19 AM   #3 (permalink)
Three to four psi under normal is enough to trigger the warning
Old 01-10-2012, 10:39 AM   #4 (permalink)
Is the spare tire equipped with a TPMS sensor?
2012 EX-L w/NAV
AndyC is offline   Reply With Quote
Old 01-10-2012, 01:44 PM   #5 (permalink)
jeproks's Avatar
no.
Old 01-10-2012, 06:25 PM   #6 (permalink)
Recently I had 4 different reading from 4 different tires. 1 tire was 38, other was 39, 31, 36 and no light.
pilotman7 is offline   Reply With Quote
Old 01-10-2012, 08:51 PM   #7 (permalink)
In my experience, if one or more of the tires is at or under 28 PSI (approximately), the light comes on. The light doesn't come on for any other condition such as overly high pressure or a wide pressure difference between tires (as long as all the tires are above 28 or so).
2012 Pilot Touring 4WD RES -- Polished Metal Metallic, black interior. OEM options: chrome side steps, air deflector, roof rack cross bars
Previous Pilots: 2003 EX 2WD, 2005 EX-L 4WD RES, 2007 EX-L 4WD NAV, 2010 Touring 4WD RES
HenryBravo is offline   Reply With Quote
Old 01-20-2012, 11:59 AM   #8 (permalink)
jp_freak33's Avatar
Another thing to consider if you are living in a colder climate is that your pressure will change with the weather. You might get in your Pilot and the light will be on but once you start driving and the air in your tires heats up a little it will expand and the light will go off. Cold tires sometimes will register 3 or 4 pounds low until you get some heat and miles on them.
Just an FYI
jp_freak33 is offline   Reply With Quote
