Nav screen flickers - Honda Pilot - Honda Pilot Forums
Old 01-01-2012, 10:41 AM   #1 (permalink)
Default Nav screen flickers
Just in the last week and getting progressively worse my nav screen flicks when I go over relatively small bumps and, interestingly, long left turns have it practically blacked out the entire time. It barely flickers on similar right hand turns.
I removed the DVD and replaced it to no avail. Is this something I could deal with or is it a trip back to the dealership?
am1958 is offline   Reply With Quote
Old 01-01-2012, 05:52 PM   #2 (permalink)
RSQ Pilot's Avatar
Garage
Look under the driver's seat from the back seat. check that no one has kicked the wire plug-ins loose causing a intermittent disconnect...give the plugs a push to tighten.
Old 01-02-2012, 07:50 AM   #3 (permalink)
I'll give it a bash.... Thanks...
