2012 Radio and Navi Anti-Theft Unlock Codes - Honda Pilot - Honda Pilot Forums
Old 12-03-2011, 10:39 PM   #1 (permalink)
techgirl's Avatar
Default 2012 Radio and Navi Anti-Theft Unlock Codes
Just picked up our new 2012 Touring AWD and was registering it to my Honda Ownerslink account. One of the things that I've always done when adding a vehicle to Ownerlink is to record the radio and, if it's installed, the navigation anti-theft lock codes. On the 2009 Pilot and my departed 2010 Acura, there were two different codes. One for radio and one for navigation. For the 2012, I can only find the radio code card. Before I call the dealer on Monday or Tuesday, can anyone confirm if I was supposed to receive one or two codes?
Thanks!
2012 Pilot Touring 4WD - White Diamond Pearl
2009 Pilot Touring 4WD - Mocha Metallic
techgirl is offline   Reply With Quote
Old 12-03-2011, 11:18 PM   #2 (permalink)
With my 11 I received two codes. I also discover that they are adhesed inside the left side of the glovebox as well.
Rob
Old 12-04-2011, 12:27 AM   #3 (permalink)
i have a '12 with Nav. You should have a card with a five-digit code which will unlock both the radio and nav at the same time. I installed a trailer wiring harness today, which required unhooking the negative battery cable. I used the code on the card after I hooked everything back up and it worked. You only have to key in the code once.
2012 EX-L w/NAV
AndyC is offline   Reply With Quote
Old 12-04-2011, 04:16 AM   #4 (permalink)
techgirl's Avatar
Thanks for the valuable information.
Old 12-04-2011, 08:11 AM   #5 (permalink)
LanceHS's Avatar
Just curious if you tried the option mentioned in the Owner's Manual on Page 394 where you can re-activate the radio/nav using vehicle specific info (the radio does a VIN check); then no need for a code?
Sent from my Autoguide iPad app
LanceHS is offline   Reply With Quote
Old 12-04-2011, 10:57 AM   #6 (permalink)
No, I did not try that method.
2012 EX-L w/NAV
Old 12-13-2011, 02:13 PM   #7 (permalink)
Default Radio Uses Code, Navi linked to VIN
From what I have read and was told the Navi is linked to the VIN so no code is required. The code you have is a Radio code.
JPSilver is offline   Reply With Quote
